blackbeard
1. After I change the oil, especially if I change the filter as well, there's always a lapse of time between when I start the engine and when it thinks it has enough oil pressure, presumably while the oil ways are getting filled with oil. Is this normal, is it healthy, and is there a way of getting around this?
2. Boat is staying afloat and in commission this winter (in a marina in Portsmouth harbour). Is there any risk of the water in the engine block (sea water of course) freezing? Should I drain the engine block before a cold spell?
regards, Mike
regards, Mike
