more turbo thoughts
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
just installed a boost gauge
getting out of the hole / increasing speed shows a temporary increase in turbo boost
at around 3000 revs the boost decreases / settles once the speed is stable
going into the 3500's the boost stays significantly higher
what is a 'sensible' boost, for engine health, to plane at for any length of time, 80% of max ?
The figures for a 42/43 engine are at 1500rmp - 16.6psi, 2500rpm - 21.0 and at 3800rpm - 25.3psi.
As it's the same turbo I would imagine for a 44 they are the same
turbo boost (maximum load):
ka(m)d42/43
1800 r/min 115 kpa
2500 r/min 145 kpa
3800 r/min 175 kpa
supercharger boost at 2000rpm
42/43 serien 70 kpa (0,7 kp/cm)
RPM KPA Bar
1800 115 1.1
2500 145 1.45
3800 175 1.75
PSI
1800 16.6 1.1
2500 21 1.4
3800 25.3 1.7
Your boost kit shows temperature of the sensor too. Mine was about 45c.
It’s sat right on top of the engine block so air intake temp likely to be somewhere between that and ambient air temp I would guess.
