More on VP DPE 290's
Morpheous
16 Jul 2009
Chippenham
I was reading the other thread on these legs with interest. I'm now coming to the end of my first year in my SS Portofino 31 - and still can't seem to observe any difference when I trim them!
So what is the theory, what should I be doing with them?
When I say no difference, the only noticable effect is trimming them up makes the pointy end stick up higher meaning I can see less! Although this was quite useful when I had a big following sea and the pointy bit was getting wetter than I was comfortable with.
From a trim perspective the boat seems to feel happier trimmed level, I usually use the tabs to get this right. These I am aware are drag but it only seems to take a little. The legs I just leave right down all the time, indicators reading about -5.
Into a head wind I also use the tabs to push the bow down to stop it slamming too much over the chop - which can be pretty wicked in the Bristol Channel. I'm sure I'm missing something here
Any thoughts or advice?
The trim of boats do differ depending on how they are loaded etc.
Try trimming the boat on a calm day to start with, sometimes there is hardly any noticable difference. With legs trimmed in (-5 in your case) get on the plane to a comfortable steady cruise. Without touching the throttles, trim out the legs 1 degree at a time and note for the same throttle setting an increase in revs and speed. Continue doing this untill for the next degree of trim out you get a decrease in revs and speed. Trim back to that value that gave you maximum revs and speed. Make a note of the trim value for future reference for similar loads and sea conditions. As said before you may not note a great difference but on some boats it makes quite a bit of difference.
Eddie
I have exactly the same on my Princess 286. Any trimming out of the legs results in a decrease in engine revs so I leave them at -5. The only positive effect I get is from the trim tabs which I raise slightly (4 seconds worth - no indicators) which gains a knot or two in good conditions
