tean
Back in the winter I posted on here about my Nanni engine and its apparent inability to warm up properly. Well in the warmer summer seawater things have improved a bit and it has been managing to get to about 70 degrees if worked reasonably hard. A quick twenty minutes at anchor to get some hot water is a non-starter though.
Now though the engine seems to have taken offence at my criticism of its underheating and has gone to the other extreme, overheating. The cause is the heat exchanger casting which has corroded through, allowing the coolant to escape into the exhaust.
The cost of a new heat exchanger is a bit over £600, and that's just the bare casting. I know the tube stack is seized in the old casting and if it won't come out intact then that's another £300, although presumably as the casting will be scrap I can just cut it away to release the tube stack without stressing it too much. So with a few gaskets I'm looking at either about £700 or £1000 to repair the engine.
Or I can pull the whole thing out and replace it with a Beta 14 which should fit onto my gearbox for about £3000.
So which to do?
The existing engine has only 800 hours on it and seems to be absolutely fine other than the rotten cooling system, so it might seem like overkill to replace it, but I am considering selling the boat after this season and am wondering what effect a shiny new engine would have on its value. It's a Hunter Pilot which is in really nice condition with a great inventory and should be worth the top end the price range, maybe £25,000. If a new engine could raise that to perhaps anywhere over £27,000 then I break even over repairing the old one.
Decisions decisions. Any comments appreciated.
So which to do?
