more eber woes
ChattingLil
3 Feb 2009
Boats in Essex and London
can't find this problem in the zillions of q's in the history of ybw - so here goes:
Monday: all working fine
Tuesday: turned on as usual -but lights only came on for second before going out and unit would not start
Wednesday: checked all connections, turned on, ran normally. Left on for hours and thermostat worked because went into standby mode and restarted fine later with no probs when temperature turned up.
Thursday: turned on, all normal.Turned off for several hours. Would not turn on again. on initial try,the lights came on momentarily, but then went out and no life at all. Now nowt at all. Cannot find anything like this in trouble shooting guide.
Have checked thermostat for crossed wires - nothing.
ideas?
What is the supply voltage ? They shut down below 11 volts just as described. Mine had this issue due to a bad connection from the domestic isolator switch.
