More Diesel drama
chas
5 Aug 2001
West Country
About this time last year, I had some very good advice when my Thorneycroft T90 decided to increase revs without warning and eventually became almost uncontrollable. As a result, I had the Fuel Distribution Pump and injectors reconditioned by Lucas CAV. I have had, until last week, a troublefree season with an engine that has behaved perfectly. The problem has now come back. The symptoms are a sudden increase in revs - usually returning to normal within about 10 - 15 seconds. A couple of times the revs have not reduced, leading to a tickover of 1200 rpm plus rather tahn the normal 500 - 600 rpm. I topped up the tank with 25 galls of fuel before this happened. Could this have had any efffect? Can it be fuel related rather than something to do with the governor or FDP? Any help or advice would be very welcome!
tr7v8
30 Nov 2001
Kent
Overspeeding is too much fuel not too little. Aside from governor and pump the other possibility would be the fuel return, if this gets blocked then you'll over fuel an that'll cause a runaway. Have you topped up with oil recently? cos diesels run just as well on lubricating oil.
Jim
jleaworthy
20 May 2002
Essex
Often an increase in engine revs means that air has got into the governor of the fuel pump. Try bleeding your fuel system again and if that works try finding out where the air is entering. It will be somewhere on the suction side, probably at a joint in the fuel line or a lift pump diaphram. Best of luck.
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
Interesting. I also have this problem once in a while with my Volvo AQD32's. Usually running at around 1500rpm (river speed0 engine will suddenly rise to 1800-1900 for a few seconds and then return too normal. Engineer aquaintance suggested dirty injectors etc and suggested I dose the tank with a diesel cleaner additive and its now far less frequent infact quite rare.
<A target="_blank" HREF=http://www.boatsontheweb.com/galleryframes.html> BoatsOnTheWeb and Boaters Photo Gallery</A>
Castletine
1 Jul 2001
Don\'t forget the Water Trap
I too have had over-revving and it turned out to be air entering the fuel system via the water trap.
I checked all filters, but it turned out to be a seal - could be worth a try.
Jonathan
Castletine
1 Jul 2001
Re: Don\'t forget the Water Trap
Yes,
The set up is as follows;
from the tank to filtre 1, then to filtre 2, then to the water trap, then to pump and injectors.
This set up has been working faultlessly for 10 years (save for the over revving) and has taken the boat down to the Med and back twice.
PeteMcK
19 Jun 2001
Summer bases Lamlash and Kip; winter Kip
Almost certainly correct
My T 90 was prone to doing this when rolling with less than about 5 gallons in the 45 gallon tank. The T 90 has a hydraulic speed governor in the CAV DPA pump (some DPAs have mechanical governors, e.g., in Landrovers and tractors). With air in there, it thinks it's running too slow and opens up the injection delivery, over-revving for a few moments. I replaced my lift pump recently, just as a matter of course (at 15 quid, why bother cleaning the old one!) and the over-revving has gone - the engine simply falters when it draws air. (My next move is to replace the tank with three small ones!)
Check for air leaks on the suction side of the lift pump, or more realistically, remake all the joints. Backflush the pipe from the tank - it might have a blockage. Strip and clean the water separator. And I'd get a new lift pump from AMC/Thornycroft, for all they cost. Change the filter anyway, even though it's on the pressure side. Now!
It COULD be fuel related too, as grotty fuel could be blocking your filters and strainers, and any air in the DPA will not be getting flushed out so readily. The air has to get in somehow though.
Re: Almost certainly correct
Good advice and probably hits the nail on the head. But check your engine oil also because if the fuel lift pump diaphragm has failed you could be both sucking air and also losing diesel into the sump. A faulty shaft seal on the DPA pump could also cause similar problems.
chas
5 Aug 2001
West Country
Re: Thanks for some excellent advice
Thank you all very much indeed. I do not really fancy taking 45 galls of diesel out of the tank (I had just filled it for the winter). I will start with a new lift pump - mine is original - and a filter change and then work along the fuel system. If I suceed, I will let you know!
Thanks again
Kurrawong_Kid
7 Sep 2001
I had this sort of roblem on a Golf Diesel car. The engine almost revved itself to destruction! A friend of mines with a similar car did just that on the motorway-very dangerous! The cause was found to be a blocked outlet filter in the fuel tank. Apparently the pump calls for more and more fuel and then the suction produces such a rush of fuel that the engine overrevs--I suggest you look for fuel starvation problems first before spending lots of money.
richardandtracy
27 Jun 2002
Medway, UK
Oil as Fuel
I once read that David Sinnet-Jones connected his diesel engine's crank case breather vent to the air intake. There was enough oil in the crank case air on a couple of (lumpy) occasions to cause a run-away. This may be worth checking.
Regards
Richard.
oldharry
30 May 2001
Re: Oil as Fuel
Diesels run quite happily on their own engine oil if it gets past the pistons, or via the crankcase breather if it is connected to the air intake as it is on the Perkins Prima for example. Normally oil should not get up the breather tube, but an engine that has worn rings/bores will build enough pressure in the crankcase to force the engine oil up the breather pipe, in to the air intake - and hey presto! unstoppable runaway engine. Had it on an old Perkins engined van once.
This form of runaway is characterised by emitting huge clouds of dirty blue smoke. Not nice in the middle lane of the M4....
chas
5 Aug 2001
West Country
The Solution!
I hope...... Thanks again for the advice. I was hoping it would be a job for the winter but went out yesterday for a last sail before laying up. Engine started racing and eventualoply went to full revs with no control. Then it stopped (in the middle of the fairway). managed to start it. Went to full revs and then stopped again. Kind fisherman gave a tow back to the mooring.
Replaced fuel filter element and fuel pump. Discovered blockage in fuel return line to tank so blew it out. Engine now running perfectly (touch wood).
The fuel filter was totally blocked. Suspect the 25 gallons of fuel that I picked up 10 days ago was to blame (absolutely no problems up to then).
DepSol
6 Oct 2001
Guernsey
Re: The Solution!
Just another lesson learnt that the fuel you get is not always tip top as the manufacturers suggest. Maybe the use of an additive might prevent all this hassle in the future....after all prevention is better than a cure and wasting your time.
Dom
I am boating again ;-)
