DAKA
Any Volvo Penta D3 engine owners best drain a little oil out so as to keep the dipstick level @ 2/3 full.
This will allow your engine oil level to self fill from the unburnt chemicals in the bio diesel that is being added to your fuel tank.
If the un burnt bio diesel is allowed to overfill your engine then your engine will manage to run on the overspill.
Your engine will be hypercharged, over rev and will not stop even when you take the throttle off and remove the keys.
On the bright side you will of course get home that bit quicker but you will need a well fendered berth
If you experience any odd throttle control, such as not slowing down when you expect then shut the engine down, check oil level and drain a little out.
I am not 100% sure that this also applies to other Volvo Penta electronic controlled engines such as the D4 and D6 along with other manufacturers ???
I dont have Volvo Penta in my boat but I still intend to keep a close eye on my oil level and run on 2/3 dip stick level .
Please note this is intended as a serious post, apparently it is already happening on current levels of bio diesel .
