BlueSkyNick
More about Raymarine ST60\'s
I originally posted about this <A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/showflat.pl?Cat=&Board=pbo&Number=500181&page=2&view=collapsed&sb=5&o=93&part=>here</A> but that has disappeared onto page 3 of the index already.
The issue is that my Speed instrument keeps changing from knots to Km/h and it appears that several others have the same problem. Raymarine initially said there was a bug in the older version of software, but mine is the latest version.
This is their latest response -
"V3.02 is the latest software revision for the ST60 speed instrument. An earlier version of the software suffered from random unit changes when the speed resolution was set to 0.00. Try changing the resolution to 0.0 and see whether the problem still occurs. Whatever the result I think we should take a look at your speed instrument and see if we can replicate the fault and then repair or replace."
So you can try changing the resolution but I think mine is already at 0.0, and anyway I should still be able to use either option. Alternatively take it up as an issue with Raymarine, or live with it !
If you have the same problem I'll be happy to collate the evidence if you post on here or PM me, so we each have a stronger case to argue. Clearly you will need to argue that case yourself as you see fit.
Personally, I am going back to the dealer for a replacement.
<hr width=100% size=1>I'm average size, Its just that everybody else is short.<P ID="edit"><FONT SIZE=-1>Edited by BIGNICK on 19/04/2004 10:37 (server time).</FONT></P>
