samuel
I have a swinging mooring on the Blackwater at St lawrence bay We have a problem because each year about 4 boats( Out of the 80 moorings there ) go adrift each year. Some boats just end up on the mud but a few are badly damaged.
There are lots of reasons such as frayed mooring lines, lack of maintenance etc etc but there is one reason that crops up regularly & that is failed mooring buoys.
We are currently using a mooring buoy that has a rod through the middle with a washer & a 3 inch ring on the top. The other end of the rod is threaded & passes through a washer that has a ring welded to it. Behind the washer is a pair of nuts the second of which has a split pin through it. The ring is shacled to the main chain.
After a season the nut threads seem to corrode & the nuts come loose. The split pin fails & the buoy falls apart & the boat goes walkabout. The chain ends up on the sea bed.
I am told that the manufacturer has recommended that the mooring line is lead to the shackle below the buoy so that the buoy has no load on it when the boat is moored. This means the line is below water for part of its length so is subject to wear faster than normal. It is also difficult to catch when mooring.
To make matters worse the buoy then swings round & rubs on the boats bow..
Suggestions such as lift the buoy on board are not really on as this is heavy & brings loads of seaweed etc on the boat deck.
We did try buoys with holes right through so that we could moor directly to the main chain & the buoy would just slip down to the water when the boat was moored. Trouble here was that the middle of the buoy just wore away suprisingly quickly. Pump up ones deflated & solid ones just fell apart. Some owners have welded the nuts on to the center bar but the galvanising goes so the whole lot corrodes quickly.
Are there any decent quality buoys on the market that overcome these problems. Ours are bought in several at a time & still cost £ 60 each so are not cheep.
Some insurers are concerned about the mooring problem & a couple of owners have had the policy refused.
Any one have experience of this in their area & how did they fix it?
<hr width=100% size=1>Justisla
