Tam Lin
I have a swinging mooring with a rod type buoy with a ring on the top. The mooring strop is attached directly to the riser chain underneath the buoy. In a wind over tide situation the boat pushes up against the buoy and the ring on the top bangs against the hull and marks it. Last year I wound rope around the ring to soften it but it made no difference. The mooring strop is quite long and I am wondering if I shortened it then would the problem be solved?
Failing that then it is time for a new buoy. I used to have a Hippo which I liked but a Google search is not very helpful. Having a ring on the top of the buoy is useful when using a pick up device as you can hook it on temporarily and I know that if I attached the strop to the ring it wouldn't bang against the boat, but I would lose a bit in security as the boat would not be attached directly to the riser.
I know that lots of us have boats on swinging moorings so any suggestions please?
