Mooring at Oakley Court
markc
Bucks & St Raphael SoF
Hi Folks
We have some friends down on Sunday so we're taking them for a potter on the river then we've booked afternoon tea at Oakley Court. When I reserved a mooring with the concierge I asked about the depth... he told me "5 meters".. ha! not likely!!!
So, question is.. how much depth is there alongside? Enough for 'drives-up' mooring, or should I use their deeper water mooring - described as "we have a wooden plank" (any other clues as to what this 'plank' is would be really helpful)
Cheers
Mark
Hopefully someone else will advise you with accuracy - but I do know that it's pretty shallow along there and I very much doubt that you will get alongside.
Not sure about the 'plank' - is that at the upstream end by the boat house.
You could always go back to the marina and take the car down :)
Oakley Ct
Moored up there for lunch a few weeks back with no problems (3ft dr).
Suggest keep away from the downstream area - that seems a bit shallow.
Oakley Court
I Know that Fringilla, the hire boat moors there often> As a timber classic she must draw 3Ft. If you raise the outdrives you should be fine. (go in bow first and pull the stern in from shore just to be sure)
