Richard10002
The above pipe is blocked and the easiest way to sort it is to replace it - If it is anything like the forward pipe it will be solid limescale such that the diameter is only about half an inch, and no amount of acid will shift it.
I've had a good look and am not sure how to reach where it goes through 2 thick cable ties behind the vanity cabinet over the toilet. I know MoodyNick replaced his on Lechwe a year or so ago, so I am looking for a "heads up" in order not to reinvent the wheel. (Having said that, I think Nick said that he is 6ft6in tall, with arms like a spider and even he had difficulty)
I removed the forward one, (approx. 8 metres), by cutting it at all points where I could reach, and replaced it by tugging it through various holes, nooks and crannies, with a piece of nylon string tied to a couple of holes made in the end.
So... I've taken the pipe ends off the pump and the seacock, but I cant cut the ties, or the pipe, through the small hatch hole in the vanity unit.
I'm toying with cutting the whole of the back panel off the vanity unit, and fitting a removable panel - something the builders should have done in the first place, (and not only here!!)
Anybody got any good reasons not to do this, or any method of cutting the ties? or any other ideas?
I also toyed with leaving the pipe in situ, blocking the ends, and fitting the new pipe around it.
Cheers for now,
Richard
Cheers for now,
Richard
