miketomison
New Member
Anyone ever managed to remove heads exit piping from behind vanity unit and sink.
My 38 was the last one they made and had a single heads amidships on port side
In the s38 I worked out by using a torch/mirror where the best place would be to cut an inspection hole in the heads. I now have a single 4" inspection hole fitted to the side/rear of the moulding with one of those dinghy style removable covers fitted. From there I could reach both up and down to cut the relevant ties. Note - I do have small arm and hands!
Thanks to Richard,Skysail and Aidy. The problem with this Moody is there are few of them. I bought it new but probably use it 3 or 4 times as much as most people.I could well be the first to do this maintenance.
The heads pipe exits through a vanity unit which at one meter off the sole and is recessed close to the hull. This area is covered by a huge mirror. The pipe is in there - great joy.There is no access from either side. I do not think I could be lucky enough to get the mirror off in one bit so it looks like protecting the whole area and chipping it off. Why Moody did not fix the mirror on a timber frame before installation........Once the mirror comes off I can make inspection hatches and fit a new mirror on a board to hide the holes. After that it goes behind a wet locker but I have no fear in cutting inspection holes there and fixing with small off the shelf fittings. I will actually start there in case I can squeeze my way into the pipe. A two hour job becomes a two/three day job because of manufacturing stupidity. Harrumph.
