What constitutes a high moisture reading for hulls. When I purchased my first boat the moisture readings were between 20 and 50 which the surveyor described as being 'low to moderate'.
Since then it's been on a drying mooring and has just had 6 months out of the water, it's been surveyed again with moisture readings of 18 and 19 which another surveyor describes as high and is using the dreaded O word.
To confuse matters further, I've just bought a Griffon which was epoxied 10 years ago, hull readings range from 12 (ultra low and same as dry datum readings taken from topsides) up to 40 (nothing to worry about I'm told). /forums/images/graemlins/confused.gif
