Simon F
Hello All,
I have the less popular fin keel version of the Beneteau First 24, and in the middle of the saloon, the dining table seems to be built around the same grp inner moulding that houses the keel box in the swing keel version. (see pic) I never actually use the table and would enjoy the extra legroom I’d gain by removing it, and as far as I can see, there’s no reason it has to be there except to hold the table up. It’s an open topped box that forms part of the inner floor of the boat and you can see down into the bilge and the keel bolts when you remove the table top. Would getting it removed weaken the hull? If so, could something be done to compensate? Fibreglassing over the removed section to give a flat floor for example? If it’s a big project I’ll probably live with it, but it seems likely the box is just a vestige that the manufacturer saw no need to omit from the small number of fin keeled versions of the model, but before taking this thought any further I want to invite the counsel of experience.
