JumbleDuck
The last time we tried to take the boat out, a change of exhaust note after five minutes suggested that something was wrong. Something was wrong: the spigot through which water is injected into the exhaust elbow had snapped off. Further investigation showed that it was made of brass with a ludicrously thin wall between screwed section and hose tail. I could have replaced it, but ASAP only do 3/8" BSP 19mm hose tails in brass, which I would rather avoid, Furthermore, the clearance between the elbow and the side of the engine compartment is rather tight, forcing a fierce bend into the hose.
I have therefore modified the system. Luckily there is a core plug on top of the elbow, the diameter of which is very close to the tapping diameter for 3/4" BSP. I had a local engineering company remove the core plug and tap the hole - much cheaper than buying the taps needed. I bought a 3/4" BSP 19mm hose tail in bronze from ASAP and reduced the threaded section by about 5mm on a lathe. The old injection point is now filled with a 316 stainless 3/8" BSP blanking plug. Both hose tail and blanking plug will be slathered with duralac before final fitting and I hope that, with the Nanni anode in the elbow, will keep corrosion at bay. However, I'll be doing regular inspection.
Costs: Hose tail £11.32, blanking plug £2.73, machining £10, packs of ten 3/4" and 3/8" copper washers £4.83 and £4.11, Duralac yet to be bought.
I thought I'd write it up here in case it's of use to anyone else - I think other Nannis use similar elbows. Here's the finished product. New hose tail at top, blanking plug on side. The small hex head on top blanks off a passageway which goes through to the inner exhaust tube - my best guess is that it's for emissions testing.
Many thanks to Stu for inspiration in his PBO articles about making exhaust fittings and to Vyv for metallurgical advice.
