ffiill
First of all a warning about modern plywood as sold at BandQ and Wickes.
I bought an 8x4 sheet of 9mm exterior hardwood ply cut up as I needed from BandQ because I couldnt be bothered getting my trailer together to carry a full sheet from one of the big timber merchants.
Other than the fact that what appeared to be a mahogany facing veneer was red die the wood seemed alright for the internal house job but having said that the bits left over have sprouted white mold on the cut veneers.This is after about 6 months in my workshop.
Then about two months ago I bought some 9mm non structural hardwood ply from Wickes for a cheap and cheerful throw away job at £20 a sheet.It looked good but as soon as I cut into it voids appeared as well as saw blunting filler.
Again the off cuts I put in my workshop where they have begun to delaminate and which are clearly glued together with fresh air.
Compare this to an exterior grade birch shuttering ply which shows no problem whatever including bits which have been outside for three years.
Be warned.
Which brings me to an old utility wardrobe I took apart.The 8 or so ply I now realise was surplus aircraft/mtb quality probably glue with aerolite. which is why it doesnt delaminate after 10 years inside my boat.!
Be warned.
