ferroboat
Our engine is a perkins 4236 and during our extended cruise this summer there may only be modern fuel avalible. Which additive should i use? Thanks in anticipation.
Do you think the continentals do the sameJust keep it clean and dry. Filter polish the fuel regularly as IMHO prevention of fuel bug is far better and cheaper than any cure. I have a simple filter / pump rig I can plug into either tank and by doing this for each tank for a couple of hours each month the fuel stays clean and virtually nothing comes out.
Your engine will tolerate a variety of diesel oils; as low as 28 seconds and as "thick" as 35 seconds. The modern (car) diesel engines will not tolerate any deviation from the present standard diesel fuel primarily due to sensors installed on the engine in order to optimise performance and economy.
The "old" engines, like my 70's marine Volvo, are very robust, to the point that they can happily run even on paraffin; however, modern diesel fuels are better lubricants, thus better for the old engines.
