catmandoo
Have just replaced my old alternators with 2 lectrica AAk 80 amp and 70 amp alternators . manufacturers literature indacates that alternator regulators are set at 14.5 volts presumably with a percentages margin above ane below that . currently getting about 14.7 volts out put on start up . both alternators discharging to common point on Sterling Reg Pro relay which at first reserves output to starter battery . problem is tha existing Sterling alternator advanced regulators seem to curt out at 14.5 voltsall lights flashing .so i am at a loss what to do .
should I play about with ignition light power currently drawing 3 amps from ignition.
Current lights measured at 3 ohms i have doubled up on cable sizes to reduce voltage drop from alternators so am now considering the situation
phoned sterling yeaterday and nice guy said " at that voltage you dont need our regulators " but later on suggested I check voltage at each length and from batteries . With doubling up I dont think so so have I a problem or is the Sterling regulator now an antique . Sterling mentions now way should it be above 15 volts but motor manufactureres says no problem
any comments please - SWIMBO is on point of abandoning ship for good .
