Mobitronic Controller Instructions Required
TradewindSailor
26 Jan 2007
New Zealand
I have an old (1988?) Mobitronic 'Controler' .... effectively a battery monitor and amp-hour meter .... part ref DCC 2012
It has two LCD displays, the left showing amps (and volts when the switch below is pressed), the right shows Amp-Hrs (and resets when the switch below is pressed).
Although the Amps reading is correct, the volts is less than that entering the box .... and the Amp-Hour calculation is totally unreliable.
I have no manual for it. If anyone has one they can email to me I would be very greatful. Otherwise I will probably scrap it.
Many thanks
