BabaYaga
Hi all,
wonder if it would be OK to mix DZR brass and bronze in an assembly of fittings for an under water through hull?
I recently ordered and received some DZR valves and fittings from ASAP Supplies, as I want to replace two old underwater through hull fittings, that could well be made of plain brass.
Unpacking the various items, I discovered something that has been discussed in previous threads, for instance in this one:
http://www.ybw.com/forums/showthread.php?361441-BSP-not-what-it-seems&p=4205861#post4205861
Namely that all the items – skin fittings, valves, T-piece, hose tails – have parallel BSP threads EXCEPT for the hex nipple, which has a BSP tapered thread.
I have read on here that using a tapered male thread into a parallel female thread is acceptable, but I would like to avoid this in order to reduce the total length/height of the assembly as much as possible.
ASAP has a hex nipple of the same size in bronze that has parallel threads. Could I use this together with the other DZR items without worries?
