Galvanic corrosion occurs under water. There are no consequences resulting from combining metals in dry conditions, which is an everyday occurrence.
I would have more concerns about the necessity of a packing piece under the clamp. Is this the correct terminal clamp ?
Probably referring to the bit of sardine tin wrapped half way round the post.If you are referring to the plastic ring around the base of the post, that's standard.
Can't see a packing piece.I would have more concerns about the necessity of a packing piece under the clamp. Is this the correct terminal clamp ?
Looks to me to be a fragment of a sticky label, at the side nearest to the camera, combined with a reflection on the radiused edge of the top circumference of the pole, on the right-hand side, giving the impression that something thin is wrapped around it.Probably referring to the bit of sardine tin wrapped half way round the post.
Specsavers....... Others can see it????Can't see a packing piece.
I think the vaseline/ grease smearing is an old school protective tip , back when the battery leaked acid from around the post. Personally not seen the occur on any modern constructed batteries.
I can seewnhat you are talking about but I do not believe its a piece of packing, sardine can or otherwise.Specsavers....... Others can see it????
See Post#9Specsavers....... Others can see it????
I was going to say it was an optical illusion, but now I might have to check if there is something in there.
I consider vaseline and petroleum grease to not be conductive enough to put on the connecting surfaces. But I do like to smear it around to keep water and salt out.
