Mixer valve (cold side) for sink tap required - Can anyone help me to find source?
alt
24 Oct 2006
Éire
Folks,
As title says, the cold valve on the mixer tap on one of the sinks won't close fully so need to order a replacement.
Can anyone point me in the right direction going by the pics below? The valve was removed with a 17mm spanner (That's the size of the big nut on it)
I've seen these taps on lots of boats before so hoping it will be an easy find.
OK now that I found the correct name for the item (ceramic disc cartridge) eBay is throwing up loads of results.... thanks for the help folks!
ALL SORTED :D
Went to local merchants, they didn't have the exact same size but I could see that the big rubber washer was universal fit. Hoping that this was the problem I swapped them round and HEY PRESTO! Didn't even mind having to buy the whole cartridge as it was such an easy fix... certainly cheaper than changing the whole tap!
