Polux
Some moths back I had wrote a letter to Yachting Montlhy magazine and as I believe the subject is important I would like to share it and have your comments and opinions about the issues at stake.
That's the letter that was sent by email:
"Before I had a boat I was already a Yachting Monthly reader (I had my first boat 30 years ago) and occasional subscriber and I am grateful for the several articles on boat stability that were published along the years and the inclusion of boat stability data in your boat tests.
This information has led me to take an interest in the subject.
In my opinion Yachting Monthly have contributed to give its readers a better comprehension of boat stability: initial stability (for carrying sail), reserve and final stability (for safety). That information as well as the AVS and the inverted stability are important criteria that any boat buyer would have interest in knowing and understanding before choosing a boat.
However I would like that on your boat tests the information on reserve stability would not be resumed only to the printing of a stability curve. The boat testers can only experience (while sailing) the initial stability, the one that is used for sailing and they do so, commenting on the boat performance (carrying sail ability, stiffness and power), but they normally remain silent in what regards safety stability. They cannot experience it (for example the capacity of recovering from a heavy knock down or capsizing) but they have the data to comment on that. So, why remain silent? Why not make that assessment as a part of all boat tests, instead of only printing the stability curve that many readers cannot understand?
I would also like to call Yachting Monthly attention for the discrepancies on the stability curves that are provided by the manufacturers.
I explain:
When you tested the Hanse 430 I was amazed by the bad stability curve that was printed. I thought that there was a mistake because the boat had a better than average Ballast/Displacement ratio and a deep keel with a bulb and it could not have an AVS under 110º, a lot worse than all French boats that have a lower Ball/Displ and similar characteristics.
I was interested in the boat so I talked with the boat designers on a boat show. The Naval Architect who talked to me said that the Hanse numbers where correct and that the French boats could not have the AVS (and stability curves) that were published and served to certify the boats. I thought that he was kidding. Everybody was wrong and he was right?
This summer I visited a boat factory and talked with the resident Naval Architect. I wanted to know why the boat I was interested in had such a good Ball/Displ ratio and only an average AVS (117º). Well, he basically said to me the same as the other naval architect. Basically he said that the stability curves that were submitted for the boat certification were not supervised by anybody and that the different programs used for calculating stability could give completely different stability curves because they didn’t use the same parameters and that many curves where “artificial”.
I was skeptical. It looked too bad to be true.
But then he showed me a lot of ORC AVS (LPS), the ones taken from stability curves that are used for rating the boats for offshore racing … and I was finally convinced. Those stability curves are all calculated the same way (for all the boats), in a credible manner.
http://www.orc.org/rules/Stability and Hydrostatics Datasheet Explanation 2010.pdf.
After all, his boat had a good stability curve, if compared for instance with a Dufour 40e, that suddenly lost about 10º on the AVS to show just a poor 110,7º.
(http://www.ffvoile.org/ffv/public/habitable1/orc/certifs/pdf/10065a.pdf).
And that is not the most worrying. The Dufour 40e is a performance boat and has a not so bad Ball/Displ ratio (32%). What would be the AVS of an Oceanis 43, if calculated by the ORC rules, knowing that the boat has a Ball/Displ of only 27%? It would be probably a lot worse than the 107º that Hanse claims for the 430.
It seems that something is very wrong with the stability data that are used to certify the boats and that are given to the public. It seems that some boat builders (or their designers) use the correct data while others use programs that give inflated results. Anyway it is completely inacceptable that the data that serves to certify boats, specifically the stability curves, are not obtained the same way in all boats, as it is the one that is used on the stability curves that are used for rating the boats for Offshore Racing (ORC).
I felt cheated and I believe that after reading this, I will not be the only one.
I leave a suggestion for Yachting Monthly: Compare the LPS (AVS) that is on the ORC rating files with the one they use to certify the boats and ask the manufacturers why the difference. Let us know what they say and please tell us in what manufacturers the difference is more substantial. "
Regards
Manuel de Carvalho
I explain:
Regards
Manuel de Carvalho
