hamishnf
New Member
Hi everyone,
I have recently assembled and installed an old md2b in my westerly windrush. It starts easily and runs fine in/out of gear with just a tiny puff of blue smoke from the exhaust. It responds well to the accelerator and doesnt make any nasty noises. Today I ran it for half an hour at lowish revs in gear without any problems whilst it warmed up. Trouble is that as soon as the engine comes up to its proper operating temperature the following happens:
It starts to puff out white smoke from the exhaust. Then it starts to lose power, the revs drop away, it doesnt respond to the accelerator, then it slowly stalls. By pressing the cold start button I can get it to restart again, but it soon slows down and stops again, and eventually it refuses to start at all, just turns over on the starter. If the engine is allowed to cool for an hour or so it starts up again and runs perfectly.
I have checked the fuel system. The lift pump pumps clean bubble free fuel right up to the injector pump. Plenty of diesel squirts out the injector unions when they are loosened off. When the cold start is depressed black smoke belches out the exhaust from the over rich mixture. So I'm sure the issue is not fuel related.
The air filters are clear, the exhaust manifold is clear (if a little sooted up).
I changed the oil/oil filter, the oil pressure is fine.
I have checked the valve clearances when the engine is hot (as it says in the manual), they are fine.
The engine pumps plenty of water out the exhaust, all cooling passages were cleared before I assembled the engine, A temperature probe reads 80 degrees centigrade on the front block. The engine isnt overheating, the problems occur when it reaches its proper operating temperature.
When the problem occured today I tried re tourqeing the cylinder head nuts and restarting the still hot engine. (the nuts had loosened up a bit) This seemed to stop the white smoke, but the engine soon slowed down and stalled again.
When I originally assembled the MD2B I used proper new head gaskets, and torqued them to the figures in the workshop manual. I visually inspected the valves, they looked to be seating ok, but I lapped them very gently with some fine paste anyway. I did not replace the piston rings, as they looked ok, I simply freed them up in their grooves.
Why is my engine running perfectly when its cold, but failing when it comes up to temperature? Any advice would be apreciated as its driving me bananas!
