rhumbunctious
Recently I replaced all the standing rigging on my '79 Westerly Berwick ketch, including adding into the mix a roller furler system that works with hank-on sails. It basically is a pair of barrel swivels with a drum which is attached as part of the forestay, so that the entire forestay rotates when furling the sail.
The main mast rigging, which is an exact copy of the original rigging, aside from the furler, is 1/4" (6mm) 1x19 316 stainless, which according to the Loos site (http://www.loosco.com/index.php?page=yacht-rigging-cable") has a breaking load of 6900lbs which works out to 3130kg, however, the furler has a breaking load of only 2700kg. The furler manufacturer assures me that it is more than strong enough for the boat, but I can't stop worrying anytime the wind picks up whether I'm going to lose my forestay.
Am I worrying needlessly? How significant is that 430kg difference in breaking load? What is a minimum reasonable breaking load for a forestay for this size of ketch?
Other than the furler, all the clevis pins for the main mast rigging are 3/8" (9.5mm) but the furler swivels use 5/16" (8mm) clevis pins (though the top of the furler drum accommodates a 3/8" pin). Would there be any benefit (or drawback) to drilling out those 5/16 holes to accommodate 3/8" pins and replacing the 5/16 pins with 3/8 pins?
