D
Deleted member 36384
Hello,
I have a Force 10 cooker, 4 x ring, oven with grill, 6 burners in total. It is the only gas consumer on the boat. I am having difficulty running 10mm pipe in one go and do not like the number of joints in the pipe.
I am considering changing the run and was wondering if 6mm micro bore would be too small and cause too much resistance to flow; it's the flexibility that would make the run easier. I have looked at the the Force 10 website and the instructions are for around 8 / 10 mm. Overall length would be about 6m.
What do you think, far too small a diameter or something that could work at full flow rate?
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
