Mimic panel circuit
aitchem
11 Nov 2003
Aberdeen, UK
Hi,
I am making a mimic/switch panel for my wee boat.
I haven't been able to find a definitive way of wiring the LED's.
What I want is, for the LED to go out should the bulb blow.
I thought it was a simple matter of putting the LED in the feed line to the nav bulb, but, it seems to be I have to make it in a parallel circuit with some resistor connected.
Would this go out when the nav bulb blows or a break in the wiring occurr.?
thx
Howard
rogerthebodger
3 Nov 2001
get some reed relays and coil the wire to the nav lights around the reed relay.
You will need to use trial and error to determine the number of coils needed to cause the reed to close. The led and dropper resistor can then be driven by the reed switch so that if no current flows to the nav bulb either by the bulb blowing of a break in the wire to the nav light the led will no light up.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
No need to get clever with relays or transistors.
If you wire an LED (with appropriate series resistor) in parallel with a 12 bulb, the LED will illuminate if the bulb blows. The bulb has a much lower resistance than the LED/resistor combination so will effectively short circuit it - until the bulb blows.
aitchem
11 Nov 2003
Aberdeen, UK
Thanks, but, that's the opposite effect to what I want.
I want the mimic panel to "mimic" what the navigation lights are doing
claudio
16 Aug 2003
Cruising
I don't think that will work.
You should still have 12V on the end of the wire if the bulb blows or not.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
Double-pole-single-throw switch needed. Wire the bulb through one pole, and the led through the other. But it won't go out if the bulb blows.
aitchem
11 Nov 2003
Aberdeen, UK
You must come from a control systems engineer, or plant maintenance background to want that sort of panel on a boat :)
............or a CONTROL Freak. :)
No, it's what I saw on a Swan, so I can pretend I have a S&S Swan when I'm flicking my switches. Anyway it cost 50 squid to water jet the aluminium.
I need to get my money's worth.
prv
29 Nov 2009
Southampton
I invested a lot of time and effort in making a nice panel for Kindred Spirit, with clever touches like the instrument and compass lights coming on with the nav lights, and the steaming light coming on when the engine is running. But I didn't feel any need for indicators to show whether the lights are lit or not - a glance up the masts when I turn them on is not exactly a chore.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
It was many years ago that I first investigated this. At the time I was sailing a catamaran with a large masthead float and it was impossible to tell if the masthead light was on or not. It seems such an obvious function that a telltale light should prove that current is flowing into the equipment rather than just the switch being on. You would have thought someone (manufacturer) would have come up with an inline 'module' that does just that.
maxi77
11 Nov 2007
Kingdom of Fife
I looked into this when I was making my light panel. You really need to monitor the current flow, so the options are the turns round the reed switch as mentioned above or the smart chips that some cars have to tell you a light has failed. When I looked they were not easy to find so I gave up.
ghostlymoron
9 Apr 2005
Shropshire
I have this facility on my Merc and find it useful especially on the brake lights which are difficult to test unless you have very long (and bendy) legs or can park outside a shop window. However, on a boat at night, you should be up on deck anyway and can easily see if your lights are working unless it's a strange kind of boat. I think you are being too complicated.
Tati B
3 Jun 2011
Cornwall
Somtimes it's nice to check the masthead light is working before you are about to set off on a passage, starting in bright daylight, but going overnight. Can't see the light in the daylight, haven't used it for a while. Do you, climb the mast to see, take the chance, or have a nice shiny instrument light letting you know it's working. It is over the top, up it is useful.
prv
29 Nov 2009
Southampton
For what it's worth, I can see my masthead light in daylight (nice bright Bebi LEDs), but I appreciate that's not true for everybody.
