lumphammer
Following on from my earlier thread on my MY30 troubles. I am looking to replace with either the Chinaspacher or Planar, what I don't want to do if I can avoid it is re-run all the heating ducts or ideally the exhaust pipes. The problem is the Mikuni uses 80mm hot air ducting and 22mm exhaust.
As far as I can find out the Planar 44D uses 100mm ducting and 24mm exhaust. I haven't been able to see what the Chinese heaters need.
Is there any chance, using suitable adapters that I can use my existing pipework?
