Middle socket on Avon foot pump.
It is probably a high pressure outlet. Outlet 1 for speedy inflation outlet 2 for slow but high pressure (above 0.25 bar for e.g.)
OK - smoke and mirrors is a perfectly satisfactory explanation. So for pumping up a bog standard dinghy with a non inflatable floor I should ignore the central socket and use the one next to the hinges marked inflation.
Yes
It is a two chamber pump. One chamber will deliver a large volume at a low pressure, the other, smaller, chamber will deliver a much smaller volume at a higher pressure.
It would take a lot of pumping to pump an entire dinghy up with the small chamber.
Its all just simple physics ... so it probably does not work!
