MF805 Storage options
freddyuk
2 Sep 2012
First off I do not see any option to "search" the forums? Is this a secret menu?
I am fitting out my MF805 and whilst working out the route for the air heating I discovered a large void up behind the port side of the front seating. Going up inside the space behind the wardrobe (I need a tiny human to hire for this work) I can see there is enough space for the heater outlet into the salon which would be under the level of the footrest and above this there is space for a large locker let into the glass fibre panel. I can also see at the bottom of this area behind the wardrobe there is no insulation against the hull so a cold spot...
I am trying not to use existing storage areas for the heater ducts which would normally have to come up in the under seat storage from the port side. For the record I have decided to put the heater on the transom which makes the exhaust pipe short. Then feed the hot air via 100mm insulated ducting along side the fuel tank and up into the void along the port side under the table right through into the wardrobe area. I am going to have an outlet in the rear deck and fit a shower option here as showering in the heads is not really on.
