Sixpence
Not my favourite subject so I'll explain as best I can.
Mast section supplied by Clive has been cut to shape for reinforcing the area of the mast where the spreaders attach, just need to clean them up a bit more and they can go on. The problem is that although they lay flush with the mast almost the full length, the ends don't. They are less than a cm off the mast but it's still a very clear gap so I'm keen to close it, but not being much good with metal, any ideas for doing this would be more than welcome.
Picture of my work so far, the only way I can think of doing it will be by clamping each end with g clamps or similar, before rivets are used to fix it in place. But it's very hard to bend so I'm a bit worried that this will just pop the rivets out as soon as the clamp's released. Any thoughts ?
