Malish
Hi
I have a '78 Rival 34 with a stainless 70L fuel tank suspended from the cockpit floor and held in place by four tangs close to the corners of the tank, the tangs attach the top of the tank to the underside of cockpit floor via threaded studs from the cockpit floor. Whilst inspecting the shaft seal at the weekend I noticed one of the tangs had failed at the welded point of contact with the tank (with subsequent slight movement of the tank) something that I didn't like to see. Whilst the perfect solution would likely be take the tank out and repair or replace, that would also involve removal of the engine and a large amount of faff. I wondered if an alternative approach would be to use a metal-metal adhesive, such as one of the 3M Scotch Weld series, to glue a new L shaped tang onto the side of the tank in order to resolve the issue. Does anyone have experience of these adhesives (I don't) - would this approach work? Take surface preparation and de-greasing with acetone as a given.
