Gustav
New Member
I have a two and a half year old Mercury QSD 220hp 2.8L.
I observed blue smoke from exhaust and smelt unburnt fuel. Pulled the injectors out and got them tested on my local engineers trigger box. Injector 3 pressured to 200bar and the other three tested to 300bar. We pulled the cylinder heads off and found that cylinder 3 had a worn valve and valve guide. So sent all 4 cyl heads and injectors to the specialist for a proper diagnosis. All 4 Injectors tested to +/- 1500bar and they all passed. The cylinder head valve guides were inspected and found to be excessively worn, one guide was severely worn which led to valve damage and blowby which made me aware of the problem.
Told this information to Barrus and they believe it’s the fuel I am using.. I purchased the boat from a friend who had it meticulously maintained and fully serviced. He was in a different marina to me where they used Ultra low sulphur (ULS) red diesel where as my local marina has MGO (marine gas oil) red Diesel. The boat had a full tank off fuel (ULS) when purchased and I have only done 50hrs before this occurred. In a nutshell the boat has been ran for 40hrs on diluted fuel ULS & MGO. I do not buy what Barrus says saying it’s the fuel? How can the valves and guides fail at so little hours on diluted fuel??? No one else has had any issues using the local fuel. As a good will gesture Barrus are supplying me with new valves and guides aswell as gaskets...
Has anyone got any Idea’s to what the problem may be?
Angus
Angus
