RICK HAN
New Member
Having replaced the impeller on a 4HP Mercury 2 stroke outboard motor, still had no tell tale water jet on starting. Used a small allen key and twisted back and forth inside the tell-tale tube. Eventually dislodged what I believe was a rather stuborn salt deposit and water jet cleared beautifully. I was suprised that it took quite a bit of steady effort to break through the deposit. Then ran Salt Away through the motor by putting in a reasonable amount of the cleaner into the recirculating water for good measure. All good. Hope this helps as removing the power head to get to the telltale would be a major otherwise.
