Mercury 4hp 2 stroke - increase power to 5hp?
corinthmistral
9 Feb 2006
Tollesbury
Hi. I have purchased a late model (2003) Mercury 4 hp two stroke outboard. The capacity and weight is identical to the equivalent 5hp model and i think i read somewhere that the 4hp can be uprated to 5hp quite easily. When it runs it "feels" as if it has a bit more to give, and doesnt rev quite as high as i would imagine it could. Hence it has the feel of a restricted motor. Has anyone derestricted one of these (or tohatsu / mariner / yamaha, which are all the same.)??? If so, what is required??? (Why do this? ... i would simply like a bit of reserve power, 4hp is enough to get my tender planing, but it doesnt have any in reserve when loaded with baggage etc. And i wasnt able to find a decent 5hp two stroke motor within 200 miles!!!) Many thanks.
I think it is the carb.
Frightening price for the alternative.
I wouldn't bother. Probably cheaper to sell and buy again.
But is it that much of an issue?
As far as I can see the slow running jets and adjusting screws are different.
http://www.boats.net/parts/search/Merc/Mercury/2003/1005201AB/CARBURETOR/parts.html
Also and probably the most significant are different stop plates for the reed valve
http://www.boats.net/parts/search/M...B/CYLINDER BLOCK-CRANKSHAFT-PISTON/parts.html
Probably looking at about £40 of parts
But, no you cannot buy them from boats.net. Mercs dont allow them to export to the UK
OTOH the carb bodies might be different...!
I bought a 4hp 2 stroke from Fairway in Fareham and they told me they could convert it to 5hp easily, but I did not ask the price at the time because it would have invalidated the warranty.
I think you will find it's the hp increase is produced by an increase in revs, and that's achieved through the jetting and set up.
Courtesy of some active t-leaves I have had the 4 and 5 versions, as well as the 4hp/4stroke, all Merc badged. Used on a Quicksilver 310 airdeck, inflatable keel, tender.
Whilst memory is a tricky thing at times I really can't remember a whole lot of practical difference in terms of performance - the real differences come about with weight distribution as you will know. The other is that the 4 stroke is heavier to handle!
Inevitably I ended up with the 4hp stroke, and the one change I did make was to enable the use of a remote tank (left behind by the t-leaves on one of their visits).
