Mercruiser, VM 4.2
david_bagshaw
5 Jun 2001
uk
Any body have a recommendation of where to get , borrow , rent, hire a code reader for a 1999 version of the above engine? even a home brew circuit diag would be an option.
engine showing a mil light, (flashing tick) on dashboard.
my mate is wishing there was an equivalent VM guy to volvo paul
Many thanks.
QBhoy
11 Mar 2016
http://download.brunswick-marine.com/filereader/file/pdf/4/enen/mercury diesel/2017/sterndrive/8m0133678.pdf
Hope this helps. I can strongly recommend that you buy a vessel view mobile device. Around the £220 mark. Will display all faults and descriptions of them on your phone or tablet. As well as all pressures and temps from the ecu. Fuel data, range, etc etc etc. amazing bit of kit. Will almost certainly tell you on screen, what your fault is. Allow you to inhibit or block it too (not that I recommend it), fault seriousness dependant obviously
DAKA
7 Jan 2005
Nomadic
1999 was very basic Technology
you just need an led , 9v battery and a couple of pins
google mercruiser Blink tester and you can make one from stuff you have on board.
count the blinks and look up the fault code.
QBhoy
11 Mar 2016
Ah. Fair point. Ignore my earlier comment about smart craft. Won’t be compatible at that age.
david_bagshaw
5 Jun 2001
uk
I have googled it and have found nothing as to how on the 4 pin socket, there is info for a later petrol engine for the method you suggest, but nowt for the 4 pin one., but can you give a lead....
Many thanks.
Fishtigua
19 Jan 2013
Guernsey
The VM 4.2 was fitted to P38 Range Rovers. I think the OBD2 reader fits, most car/truck garages have one. Or about a tenner on ebay.
