Paul1962
Hi,
I Would love some advice please.
My Mercruiser V6 4.3LX (2 barrel MerCarb) is fine all day at the lower RPMs ie 3000 ish or lower - no problems at all.
Ask it for full noise - circa 4200 in my case and it will go for about 2 to 3 minutes and then it starts missing or just cuts straight out.
Sometimes it will restart immediately, sometimes it will keep going if I reduce rpm to around 3000 and sometimes it will cut straight out and refuse to go again for about 20 minutes.
I have changed fuel line, changed the fuel filter (it is a genuine Quicksilver), checked the carb inline filter, changed and proved the fuel tank vent and finally today fitted a replacement ignition coil (yes, the +ve & -ve are on the correct terminals and I checked it out with my multimeter first).
The only thing that I think may be linked is that the Tacho sometimes works and sometimes doesn't - no correlation to any of the engine failures though.
I am now stumped - anybody out there come across this before or know what it may be??
Any advice gratefully received.
Thanks in Advance
Paul
Thanks in Advance
Paul
