jhr
The good news is that the boat's back in the water.
The bad news? Well..... Engine started up absolutely fine (always has done) and I warmed up and moved her round to an accessible pontoon to get some gear on board. All well, except that I was having problems going into reverse. It wouldn't engage until I'd upped the revs to about 1,500, then she took off like a scalded cat (naturally). Going ahead was OK. We moored up, switched off and loaded up.
I started up again and the engine fired up and if a bit of throttle was applied it'd run OK, though sounding a bit hesitant, but the moment I dropped back to tick-over it stalled. Engine was at operating temperature and everything else looked tickety-boo. Same thing happened about a dozen times over the next ten minutes, at which point I stopped both to spare the battery and to prevent a fusillade of bad language in front of the children.
Any ideas? Instinct says it might be a throttle cable problem, assuming the two problems are linked, but any other suggestions? Engine is a Merc 5.0l efi with Alpha One leg.
Due to ring the boatyard tomorrow (they rang me on Friday to asure me that everything was working /forums/images/graemlins/wink.gif) and it would be nice to have some idea of where to start.
tia.
tia.
