Mercruiser Rev Counter Flicker???
paultallett
25 Mar 2009
At work!!
www.caymanreef.co.uk
Hi,
First post, so please be gentle. Had an ace Easter, boat back in the water, clean bum, fully serviced engine etc......Had a fantastic shake down trip from Portsmouth to Lymington and back.
Boat performed beautifully and all is well with the world.....Then once off the plane and doing a steady 6knots back in to Portsmouth the revcounter on my Mercruiser Mag350 started to flicker, anything from 200 - 800 rpm from where it had been showing. Engine was absolutly fine with no engine note change and the speed stayed steady.
Must be a loose wire / connection / faulty gauge....anybody had a similar experiance so as to point me in the right direction before I start poking around next time I'm at the boat?
I would have had a look yesterday but my crew was desparate for the rides at Southsea......I obviously need to keep a bigger stick on board to control mutiny!!!
Regards,
Paul.
Welcome aboard Paul(sorry 4 pun), glad you enjoyed your first outing this season. Start with easy stuff as mentioned,remove wires and clean connectors but as they're probably electronic gauges,it could be a fault within the unit,and if thats the case,you'll probably be buying another unit. Try ebay
If its a black dial with blue mercury on it I have a spare one unused I could sell you, send me a pm if interested. Fits everything from outboards to V8.
The reason I have a spare is mine was flickering 5 years ago.
There are some dials on the back that you set for
2 cylinder outboard
4 cylinder
6 cylinder etc
If the dial gets knocked then your rev counter will flicker.
Hope that helps but if not I am open to offers on the rev counter.
Thanks for all your quick replies. I think it will be a case of work through all the contacts and suck it and see.
Thanks for your kind offer DAKA, the rev dial is a 'Faria' so in the interest of keeping everything the same, I guess if it comes to replacing the dial I'll have to go down the dealer route.....
Regards,
Paul.
I have had similar problems with the revcounter fluctuating and reading double what it should, after winter storage.
Daft as it sounds I was advised by Merc dealer that it may be a poor internal contact and to "thump it" as we did with old teles years ago. I thought "well it cost nothing to try" Thumped it and lo and behold it fell back to a steady and correct reading.
Welcome mikej
Now thats just the solution I was after......No more chasing wires, just give it a good thump!! Got to be worth a try!! Brill, thanks for that Mikej /forums/images/graemlins/cool.gif
