salar
Hi all, I have read some very informative posts on Mercruisers here so I hope someone can help with my problem. I have a diesel Mercruiser on a Trophy sportfisher which has run perfectly for 5 years. Last season I had occasional problems when it would drop revs from cruising speed (3,000 down to 2,500) then climb back again. This would happen a couple of times a trip, irritating but not really a problem. This season the problem has got progessively worse and last trip it would not rev beyound 2,500 at all, when it did it would drop back then climb up again only to drop back again. My local engineer is perplexed. We have changed the primary fuel filter in case there was muck or bug, it is clean. My next step is to call in the guys with computers but that will be expensive and the local engineer is not convinced that will find the problem. Has anyone else has this problem with a Mercruiser? Is there any other fault-finding I should do? Thanks in anticipation...
