gorb
Anyone help with a strange problem? We have a Westerly 33 with a Merc OM636 42HP diesel. Until the big cruise this summer, the donk has run perfectly.
However, we now find that when hot (running for an hour plus) the diesel will suddenly drop 200 revs. It will stay like this for a minute or so, then return to cruising revs of 2000rpm. Very occasionally revs wil drop to 1000rpm and only return to cruising revs after a few minutes or after adjusting throttle up and down a few times. Despite all this, the engine runs perfectly at (its) selected revs. Just that the engine decides revs - not me!
It's definitely NOT fuel - this has been checked and rechecked. There is no smoke, black or otherwise. Air filter is clean and well fitted. There is no air in the fuel lines - they have been checked and bled.
After each incidence, engine returns to normal running and the fault may not recur for a few minutes or, more usually, a few hours. To repeat, the engine runs smoothly at all times, with no hesitation, smoke or other unusual behaviour - just the drop in revs.
Could it be a governor problem in the high pressure pump? Any suggestions very welcome.
