Megellan 310
SteveA
31 Dec 2001
Cumbria. UK
I've an elderly Megellen 310 GPS which keeps searching for fixes and occasionally picks up one or two satellites but but fails to get a fix.
Is this terminal or is there some magic button pressing that can give this a reset?
My 320 did these in the summer and i eventually gave up on it. dont think there is much you can do. I use mine for racing and a back up for the main set. so decided i should not risk having a set that occ picked up a position and bought a new one. A Garmin gps 60 very pleased with it.... these things are so cheap nowadays.
My sailing has been delayed - I now have a blocked sink to clear, so I'll go sailing after lunch.
Anyway, to reset a Magellan 310:
Make a note of all waypoints that you have entered as you are about to lose them.
Switch off.
Press and hold the right arrow.
Switch on.
A message will appear asking you if you want to delete memory.
Select yes.
I can't remember if you then need to switch off again, or if it will behave itself correctly from this point on.
Regards.
Pete,
Many thanks - it took about 10 minutes to boot up from cold but now working perfectly!
Without your help I'd have binned it!
Steve
