measurements from a modern 15hp Honda
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
I wondered if anyone knew of some accurate measurements or drawings for a modern Honda long shaft 15hp
manual start
does anyone have one around their shed/garage that they could take some snaps with a tape measure up against it?
this is the one I want measurements for
http://m.marine.honda.com/outboards/motor-detail/BF15
What exactly do you need Dylan? I'll see if I can pull it out of the Honda system...
this is the BF10 in position
www.keepturningleft.co.uk/wp-content/uploads/TrueCAD-HONDABF10D.pdf
I need the dimensions of the 16 engine at the point it passes through the cockpit floor and the point at which it passes out the bottom of the hull
I plan to drop it in at right angles until the tplate passes through the hull and then rotate it to be in line
the well will be a slot that is slightly wider than it is long
I have seen a Hurley with the same arrangement
D
Couldn't pull anything out of the online system Dylan. However, I may be down with the mechanic today on a boat installation - I suspect there will be a page in the workshop manual with these dimensions - unfortunately i'm on my own on the desk at GF today so very little time to do any researchy things, but if I can grab and photocopy quickly I will grab it for you...
EDIT : Hold that thought, the mechanic is going to pop up and show me where I can access the workshop manuals online....stand by... ;)
we have drawn up a couple of cads
http://www.keepturningleft.co.uk/scuttlebutt/well-cads/
I will make up a well template out of thin ply and take it to an outboard
D
It strikes me that there's not going to be much room for your crew and dogs.
Are you suggesting using the engine compartment as a dog kennel?
you know I had not really thought of that - but by jingo you are correct
I shall start feeding Maggie Up to help bring the boat back to her lines after removing the 250kg engine
I shall just go and give her the good news that she will be on ad-lib "Yummie Chops" from here on in
Oh hello - she is now sitting beside the desk looking expectantly at me with those soft brown eyes
she must know what I have just written
D
