gandy
Hi,
Our MD7A has never passed much water, but until last trip never showed any signs of overheating. Water was never more than comfortable handwash temperature, and the engine never felt (or smelled) too hot.
Last trip when we were motoring against the tide, slightly higher revs than normal but not full power, the exhaust note suddenly changed and nothing but steam was coming out. Reducing down to tickover brought things back to normal. Trying again later if I ran at more than something like 1500rpm or so the exhaust water started to get really hot, but again returned to normal when easing off a little.
I've checked the obvious things for a sudden change, the cooling water intake and the impeller and nothing seems wrong there. When I changed the thermostat a few years ago I took the exhaust manifold off as well and cleaned that all out, also the checked the connections to the cylinder head.
Unless anyone has other suggestions, I think I need to check for blockage in the gearbox. I've seen that suggested. What's the best way to do so?
Any other suggestions appreciated. I have to say that taking that manifold or the thermostat housing off again is a real last resort. Both were so corroded they basically had to be stuck together with silicone to keep them water tight. If they have to come off, that's probably the end of the engine.
Thanks in advance, Tony S
