gandy
Hi,
We're replacing the fuel tank on our Griffon, and I need to get it ordered pretty soon. I've done all the measuring and worked the correct fittings and their appropriate places.
I just need to decide whether to stick with the existing feed arrangement with the fuel tap at the bottom of the tank, or to go with the so-called modern practice of drawing from the top via a dip tube. As far as I can see the disadvantage of the top feed is that any sort of small leak is likely to go unnoticed as air will be sucked in rather than fuel leak out, and of course that will stop the engine. Also there's an extra complication in the fitting of the dip tube, and again any imperfection or fault there will bring things to a halt.
Conversely using the original method the fuel supply to the engine is more secure, but with the risk that a fuel leak from pipework etc could empty the whole tank. I'm inclined to favour sticking with this arrangement.
One possible issue may be that the tap can't be fitted as near to the bottom of the tank as I would have liked, maybe leaving a greater unusable volume than I would have with a dip tube feed. I intend to mitigate this a little by sloping the tank by around 10mm. Its unfortunate that access to the space means I need to fit a fairly flat tank.
Any comments or thoughts? In particular I would be interested in experience from anyone with a similar age or type of engine. The comments from other owners all seem to be from people who've replaced the engine as well.
Thanks, Tony S
Thanks, Tony S
