Pitterpatter
Hi,
I have just put my boat back in the water and the winter seems to have brought on a new problem - that I cannot see in any other posts.
When the engine - the dear old MD2B, fired up first time, no cooling water was coming out. I stopped it quickly and tried again. Again nothing. Checked the impeller and all seemed fine so started up again and water started pumping straight away.
Next time on the boat, I tried again and again no water was coming out. I switched off and tried a few minutes later and again nothing for about 30-40 seconds then water started coming out.
I put this down to the thermostat actually doing what is says it will and directing the water around until the engine is warm then pumping it out once up to temperature (I know - the fact that it acted differently is worrying).
So last week I went for the first sail. Armed with my new knowledge I motored out of the harbour. But with the engine working it quickly built up temperature, then no water appeared and it quicky headed towards overheating. We got the sails up and switched off and forgot about it for a few hours.
As we returned to the harbour we reduced sail and sailed into the marina (always makes you popular) as we knew the engine was going to everheat. Starting up at the last minute, water immediately started pumping out, so no danger.
Has anyone seen this sort of thing before. It sounds like a thermostat issue to me, but I have been wrong many many times before so thought I would check if anyone else has seen this before I start tampering.
