MD22P coolant replacement: what is inside a calorifier?
Thanks, so I'd better get 15 litres rather than 10. I think it is ready to use, but it's in Spanish :)
You need to figure out if its ready to use or requires diluting. If the water supply is hard it makes sense to deliberately buy it ready to use or, if you follow Volvo's recommendations, you should otherwise be diluting with distilled or demineralised water.
Have you decided if you should be using a long life / OAT type or a conventional low silicate type ?
