AHoy2
As follow-up to an overheat event on my VP MD2020 I have made some temperature measurements and would like the opinion of forum members with real world data/experience to compare with.
The measurements were made after one hour running at a steady 2,000 rpm, with a corresponding boat speed of just under 5 kts. An extended full load test is to follow once I have verified the data so far. The boat is a 31ft AWB fitted with a KIWI prop that is pitched to give 3,500 rpm at WOT.
Temperature measurements (all deg centigrade):
Seawater inlet pipe: 18
Seawater filter: 21
Heat exchanger top adj. to inlet 65
Heat exchnager top adj. to outlet 45
Heat exchanger bottom inlet side 74
Heat exchanger bottom outlet side 56
Exhaust elbow 21
Cyl head at base of injectors: all 3 around 80 deg.
Calorifier feed: 77
Calorifier return: 75
Observations welcome.
AHoy2 you.
Seawater filter: 21
Exhaust elbow 21
Calorifier feed: 77
AHoy2 you.
