Saddletramp
Ideally I would have liked to post a video here of my Volvo MD 2 running again after replacing broken pushrods but I can not seem to do it. Any advice welcome.
Thanks to advice and comments from forumites. And no I have still not found the cause, I will have to keep an eye on oil at the top end etc. At least it is running again.
I have white smoke, (it was there before as well) Injectors checked. They told me it was timing too retarded. There is a way to check it if you have the correct volvo tool which I do not. Failing that I was going to try and remove gaskets from the injector to adjust it until it improves. The question is to retard the timing should I add or remove gaskets. My feeliing is to remove them.
Or could it be another problem, perhaps with the injector.
